wrangler_tj Geplaatst November 16, 2005 Rapporteren Share Geplaatst November 16, 2005 Hieronder een artikel uit jpmagazine over het monteren van een turbo op een 4.0 liter HO motor met serieus vermogen- en koppeltoename, lijkt mij zeer interessant en goed ok zelf de kit samen te stellen en dan te monteren. Hun kit vindt ik veel te duur, voor wat het eigenlijk is. Hierbij: Turbo op 4.0 liter Turbo 4.0 No longer stuck in the slow lane. By John Sweetser Photography: John Sweetser A Jeep does what it is designed to do very well - climb steep, gnarly slopes at slow speeds. However, if you have to travel some distance to get to your favorite climbing spot, you have probably found that the Jeep isn't designed to maintain freeway speeds in the mountains or when larger tires are added. Many times, with the six-cylinder in our '99 TJ, we've been stuck in the slow lane, especially when heading west on I-70 out of Denver. The solution seemed obvious - more power - but how best to do it? We tried a number of techniques: an air intake system, a throttle-body spacer, new headers, an after-cat exhaust system. These made a small improvement (or maybe we just imagined they did), but we were still intermingled with the 18-wheelers on I-70. It was time for more drastic action. We looked into superchargers, but they are expensive and cause a sizable drop in gas mileage. Next we looked into turbochargers, which are commonly found on big diesels and small imports. While a supercharger is belt-driven off the engine, a turbocharger is powered by exhaust gas, an untapped source of power. It takes engine power to spin the supercharger's belt, but there's no parasitic power loss with a turbo. A turbo has no beneficial effect on engine performance below around 1,500 rpm, but at around 1,800 rpm it starts to take off - just what we needed for the mountainous Colorado roads. We searched the Web for turbos and found a Jeep turbo kit from 505 Performance in Farmington, New Mexico. Designed to push 6 psi of boost through the intake manifold, it is a complete kit that comes with everything you need to install it — the turbo unit, the exhaust pipes for routing the exhaust to/from the turbo, the fuel-management unit, an oil pan which contains a return oil-line fitting, and various brackets and hoses. The block diagram to the right shows how the turbocharger kit is installed. To be able to compare the before-and-after performance, we first took the Jeep to Redline Motorsports in Fort Collins, Colorado, to obtain a baseline. Redline strapped it to the chassis dyno and measured 148 rear-wheel horsepower. That was surprisingly low, but up to 30 percent of the horsepower can be lost in the drivetrain, along with another 3 percent loss per thousand feet - Fort Collins is, after all, at 5,000 feet. The turbo kit offered by 505 Performance comes complete with everything you need. The oil pan at the top contains the fitting for connecting the return oil line from the turbo. How Does It Work? With the turbo and its components installed, the next step was to adjust the fuel curve, which we did using an Innovate Motorsports computer that came with the kit (it can be returned for a rebate if you don't want to keep it). We plugged the computer into the O2 sensor port just after the turbocharger and adjusted the air/fuel ratio using a screw on the FMU. No change to the engine's computer was necessary . Initially, our manual-transmissioned 4.0L Jeep started knocking at around 4,200 rpm. Prior to our install, 505 Performance had only put its turbo kit on Jeeps with automatic transmissions. Those Jeeps hadn't experienced engine knocking. To solve the knocking problem, we purchased an MSD Boost Timing Master. It works by delaying the spark a user-set amount for every PSI of boost in the intake manifold. Delaying the spark 1.5 degrees per pound of boost eliminated the knocking. We took the Jeep back to the dyno for the final precise tuning. Adjusting the wastegate, we decided to run around 6.5 psi of boost, which resulted in 214 hp to the rear 31s. Before After Increase Horsepower 149 214 44% Torque 191 281 47% The heart of the system is a Garrett T60 turbocharger unit. The opening shown is the exhaust system inlet which drives the turbine wheel. Now the Jeep flies at 11,000 feet. It's a left-lane, 75-mph vehicle. In theory, the turbo shouldn't affect the Jeep's operation at low rpm on the trail. However, as they say, "One experiment is worth a thousand expert opinions," and we wanted to make sure. During low-rpm off-road climbs, there was no change in the Jeep's factory climbing ability, which was a great relief since that's what Jeeps are for, after all. Theoretically, the fuel economy should stay about the same under non-mountainous cruising conditions. This is because the fuel management unit only increases the fuel flow if the turbo is generating boost. During freeway cruising, we noticed about a 1-to-2-mpg decrease. The first task was to remove the old exhaust system between the exhaust manifold and the front of the catalytic converter. This allowed us to remove the existing oil pan and install the oil pan provided with the kit. The new exhaust system (left) is routed up through the turbo instead of straight back to the catalytic converter. The hole in the exhaust-system flange mounts to a corner of the air-conditioning bracket for support. Now that the Jeep is turbocharged, we'll need to observe some extra precautions, such as letting the engine warm up for 30-60 seconds prior to driving to ensure that oil is flowing to the turbo. Before shut down, the engine should be run for 30 seconds to allow fresh (and cooler) oil to displace the heated oil in the turbo. And changing the engine oil every 3,000 miles is now more important than ever. If you go the turbo route, be prepared for some unusual noises from the turbocharger. As you let off the gas to shift and the rpm drops, the still-spinning turbine will build up excess boost (since the boost is not being consumed by the idling engine at this point) and will trigger the wastegate to open to bypass the exhaust gas around the turbine wheel. This is accompanied by a very loud woooosh. Depending on your frame of mind, this can be either an annoyance or an asset - we personally felt this was an awesome sound, and it certainly grabbed the attention of startled onlookers. Expect the turbo installation to take about 10-12 hours plus an hour of tuning. Once the exhaust system is installed, the turbo mounts to the four holes around the exhaust system outlet. A hole was cut in the wheelwell below the turbo to help cool the unit. Steel piping connects from the turbo to the throttle body. The braided steel hose is part of the wastegate system. When the boost pressure gets too high, the actuator connected to the lower end of the hose opens the wastegate, allowing some of the exhaust gas to bypass the turbine wheel. This, in turn, reduces the amount of boost generated by the compressor wheel. To lubricate the turbocharger, we installed a T-fitting at the oil sending unit and a braided steel hose to a fitting at the top of the turbo. From here the oil passes through the turbo and down the drain hose through the fitting on the new oil pan. We connected the fuel management unit (FMU) into the fuel lines at the framerail. The other side of the FMU feeds the fuel rail. The FMU also has a reference vacuum line that goes to the intake manifold to adjust the fuel pressure according to the manifold’s boost pressure — the more boost pressure, the more fuel the FMU provides to maintain the proper air/fuel ratio. We mounted the FMU in the inner fender just under the brake master cylinder. With the installation and testing complete, you might think we're done. However, there are a number of other enhancements we could make, such as adding an intercooler between the turbocharger and the throttle body. Because compressing air causes the turbo to heat up and heated air has less density, an intercooler can increase the efficiency of the turbo by decreasing the air’s temperature and thereby increasing its density. A blow-off valve can be attached to vent excess boost pressure when the throttle-body door closes - the blow-off valve would be triggered by vacuum in the intake manifold. Forged low-compression pistons, also carried by 505 Performance, can be installed to allow the engine to operate at higher boost levels. Like all things Jeep, the list is virtually endless, and as usual, it depends on how much money you want to spend. Citeren Link naar opmerking Deel via andere websites More sharing options...
87wrangler Geplaatst November 18, 2005 Rapporteren Share Geplaatst November 18, 2005 Vermogen en koppel krijgt 'ie zo zat! 't Is dus in ieder geval echt tunen en geeft echt vermogenswinst! Ik begrijp alleen niet dat ze er dan niet gewoon een V8 in hangen... Citeren Link naar opmerking Deel via andere websites More sharing options...
dree Geplaatst November 30, 2005 Rapporteren Share Geplaatst November 30, 2005 wat kost dat ding eigenlijk ? want zie ik niet in het artikel Citeren Link naar opmerking Deel via andere websites More sharing options...
wrangler_tj Geplaatst November 30, 2005 Auteur Rapporteren Share Geplaatst November 30, 2005 wat kost dat ding eigenlijk ? want zie ik niet in het artikel Hangt ervan af welke je monteerd tussen de $3000 en $4000 maar dan is alles bolt on en alles past perfect op elkaar. Heb voor mezelf eens bekeken wat het zou kosten om zelf de kit samen te stellen en kwam op een max van € 1000 waarvoor ongeveer € 500 voor de turbo, dan nog wat olieleidingen en op maat gemaakte uitlaat en andere benzinepomp. Citeren Link naar opmerking Deel via andere websites More sharing options...
Kameel Geplaatst November 30, 2005 Rapporteren Share Geplaatst November 30, 2005 Enorm mooi idee, al ben ik van mening dat de TJ niet gemaakt is voor regelmatige lange afstanden met hogere snelheden. Maar voor een XJ of ZJ met de I6 lijkt me het best een aardige invalshoek. Over het verbruik: 1 tot 2 miles per gallon lijkt misschien niet veel, maar de standaard TJ zit op de 17/19 MPG en dan is het toch best veel wat je op vlakke weg meer gaat gebruiken. Citeren Link naar opmerking Deel via andere websites More sharing options...
Bartman Geplaatst November 30, 2005 Rapporteren Share Geplaatst November 30, 2005 Hebben jullie dit al eens gezien ? Avanger Supercargers Mooi he ! Citeren Link naar opmerking Deel via andere websites More sharing options...
A.J Geplaatst November 30, 2005 Rapporteren Share Geplaatst November 30, 2005 Vermogen en koppel krijgt 'ie zo zat! de vraag is echter, is het bruikbare vermogen en koppel. Heel leuk zo'n uitlaat compressor maar die begint pas goed te werken bij hogere toerentallen. En dat wil je niet hebben met terreinrijden. Beter is om een V-snaar aangedreven "turbo" te gebruiken en het beste is de Twin screw compressor. fabrikanten lysholm kenne bell whipple diverse review betreft geforceerde luchtinlaten forced induction Als je er een turbo op gaat zetten hou er dan wel rekening mee dat je de motor zwaarder gaat belasten en hierdoor de motor sneller gaat slijten. suc6 Citeren Link naar opmerking Deel via andere websites More sharing options...
