aw12345 Geplaatst May 19, 2012 Auteur Rapporteren Share Geplaatst May 19, 2012 Started on my weekend project Citeren Link naar opmerking Deel via andere websites More sharing options...
aw12345 Geplaatst May 19, 2012 Auteur Rapporteren Share Geplaatst May 19, 2012 Weekend project continues. Looks like this poor axle got it self some pretty good Hammer love Citeren Link naar opmerking Deel via andere websites More sharing options...
michel1972 Geplaatst May 19, 2012 Rapporteren Share Geplaatst May 19, 2012 It looks like it got to much love....... Citeren Link naar opmerking Deel via andere websites More sharing options...
aw12345 Geplaatst May 20, 2012 Auteur Rapporteren Share Geplaatst May 20, 2012 Nah not nearly enough Wanted to weld the axle tubes, making good progress, but yes it has had some rock kisses Citeren Link naar opmerking Deel via andere websites More sharing options...
aw12345 Geplaatst May 28, 2012 Auteur Rapporteren Share Geplaatst May 28, 2012 After our little put put through the mountains and into the desert yesterday, it seems like it might be a good idea to make a stinger style spare tire carrier. I cut a pre cut sidewall on a front tire, busted it pretty good so instead attempting a to plug and reseat the darr thing borrowed the spare of one of my wheeling bud's. Got to love people that run the same bolt pattern and tire size as you do lol. Any way for some local trails it seems like a good idea and the thing stuck on the back doesn't look half bad. Mangled a fence pipe to see what it will take to make a stinger style spare tire carrier work Kinda getting there, inspector Meathead says it will work Citeren Link naar opmerking Deel via andere websites More sharing options...
REAL STRANGLER Geplaatst May 28, 2012 Rapporteren Share Geplaatst May 28, 2012 He Aart, betekent dat dat je niet meer met de Pittbulls gaat rijden? Heb je ze al verkocht? Wij hadden grote moeite met het vinden van 42" bandjes in de USA ! Blijkt dat de Goodyear produktie van echte mannen maten al meer dan een jaar stil ligt. siert. Citeren Link naar opmerking Deel via andere websites More sharing options...
aw12345 Geplaatst May 28, 2012 Auteur Rapporteren Share Geplaatst May 28, 2012 Nee hoor, ik ben nog steeds blij met de Pitbulls. Is altijd leuk om andere dingen te proberen. Begon met een set oude krawlers om te zien hoe de Jeep op de weg reed. Want ik wilde er mee naar Big Bear. Dat werkte, een maand of 5 terug had een vriend een set gebruikte 37" sticky Krawlers te koop en leek me een goed idee om die te proberen. Die werken awesome, alleen jammer dat er eentje een cut in de sidewall had die dus overleden is. Zal eens kijken of dat nog te repareren is. Heb nu mijn ogen op een set 40" mtr stickies, alleen zelfde verhaal eentje is no good. Wat ok is heb tot het midden van de herfst tijd om er nog eentje te vinden. Was gisteren met de gearing kalkulator aan het spelen en met 40" banden en de 6 speed de crawl ratio is het zelfde als de 5 speed met 37" banden dus dat zou goed moeten werken. Er is een trail in JV waar je niet te breed moet zijn, dat een van de redenen was om andere banden te proberen. Het over de weg rijden is opgelost, mijn nieuwe pickup doet ok om mijn trailer met Jeep de bergen in te slepen. Om het op te sommen heb fun met het experimenteren met banden. Geometry van de achterwiel ophanging is nu naar mijn zin, en nu is het kijken wat ik met banden vinden kan. De stickies slayed Moab, is ongelovelijk het verschil in traction tussen blue label Krawlers en de red label Krawlers Citeren Link naar opmerking Deel via andere websites More sharing options...
aw12345 Geplaatst May 29, 2012 Auteur Rapporteren Share Geplaatst May 29, 2012 Will copy the bends of this thing, make it out 1.5" 0.120 wall tube, then add a tube between the legs so I can bolt the tire to it that part will extend forward so I can attache it to center of the lower cross bar of the cage and that's it, one tire carrier build. The krawler weighs 100lbs and I can take probably close to that in junk out of the back of my Jeep so weight wise it wouldn't make much of a difference. Citeren Link naar opmerking Deel via andere websites More sharing options...
aw12345 Geplaatst May 30, 2012 Auteur Rapporteren Share Geplaatst May 30, 2012 First of disappointed in the sidewall strength of the krawlers, darn sidewall sliced like a knife went through butter, my doggies would have laughed at that. Anyway found some other Sneakers Bend me my pretzel, will see if I can finish that thing in the next few days Citeren Link naar opmerking Deel via andere websites More sharing options...
aw12345 Geplaatst May 30, 2012 Auteur Rapporteren Share Geplaatst May 30, 2012 Made a bit of progress today Citeren Link naar opmerking Deel via andere websites More sharing options...
Ogdak Geplaatst May 31, 2012 Rapporteren Share Geplaatst May 31, 2012 What kind off a bender do you use? Citeren Link naar opmerking Deel via andere websites More sharing options...
aw12345 Geplaatst May 31, 2012 Auteur Rapporteren Share Geplaatst May 31, 2012 I have used several different ones, mostly the ones that are based on the JD square benders. One of my friends build one that bends vertically which is a better setup makes it easier to get all your bends correct. The benders have some play in them so when you bend horizontally often some of your bends end up being of a few degrees due to the play in the bender and the weight of the tube being bend. That make sense? other than that they are awesome benders for the money Citeren Link naar opmerking Deel via andere websites More sharing options...
aw12345 Geplaatst June 1, 2012 Auteur Rapporteren Share Geplaatst June 1, 2012 Just needs some paint and I need to make or find a nice lynch pin Citeren Link naar opmerking Deel via andere websites More sharing options...
Ogdak Geplaatst June 1, 2012 Rapporteren Share Geplaatst June 1, 2012 I have used several different ones, mostly the ones that are based on the JD square benders. One of my friends build one that bends vertically which is a better setup makes it easier to get all your bends correct. The benders have some play in them so when you bend horizontally often some of your bends end up being of a few degrees due to the play in the bender and the weight of the tube being bend. That make sense? other than that they are awesome benders for the money Thanks on the info. Citeren Link naar opmerking Deel via andere websites More sharing options...
aw12345 Geplaatst June 1, 2012 Auteur Rapporteren Share Geplaatst June 1, 2012 Thanks on the info. You are welcome Otto Citeren Link naar opmerking Deel via andere websites More sharing options...
aw12345 Geplaatst June 2, 2012 Auteur Rapporteren Share Geplaatst June 2, 2012 Got er all painted up and had to try a bigger sneaker Citeren Link naar opmerking Deel via andere websites More sharing options...
michel1972 Geplaatst June 2, 2012 Rapporteren Share Geplaatst June 2, 2012 Very nice! Looks great. Citeren Link naar opmerking Deel via andere websites More sharing options...
aw12345 Geplaatst June 2, 2012 Auteur Rapporteren Share Geplaatst June 2, 2012 Bedankt Michel Citeren Link naar opmerking Deel via andere websites More sharing options...
aw12345 Geplaatst June 23, 2012 Auteur Rapporteren Share Geplaatst June 23, 2012 Today's little projects Made a license plate mount on the tire carrier Added a bit of tube to the cage. Also got the last 40" MTR delivered by Brown Santa. For decent price on MTR's and free shipping to some states check this place out. http://www.ebay.com/itm/4-NEW-35-12-50-17-GOODYEAR-WRANGLER-MTR-KEVLAR-1250R-R17-TIRES-/310402573554?pt=Motors_Car_Truck_Parts_Accessories&hash=item48456f64f2#ht_2313wt_947 On to today's projects Citeren Link naar opmerking Deel via andere websites More sharing options...
aw12345 Geplaatst June 24, 2012 Auteur Rapporteren Share Geplaatst June 24, 2012 Citeren Link naar opmerking Deel via andere websites More sharing options...
EJG Geplaatst June 24, 2012 Rapporteren Share Geplaatst June 24, 2012 Why more tube ? Citeren Link naar opmerking Deel via andere websites More sharing options...
aw12345 Geplaatst June 24, 2012 Auteur Rapporteren Share Geplaatst June 24, 2012 triangulation, de voorste tube is het zwakste punt van een rol cage en heeft alle hulp die het kan krijgen nodig Citeren Link naar opmerking Deel via andere websites More sharing options...
aw12345 Geplaatst June 29, 2012 Auteur Rapporteren Share Geplaatst June 29, 2012 My little put put Jeep wanted some other sneakers, some heavy SOB's too. Took some serious man handling to mount them, get them of the tire machine and get them puffed up. Looks pretty cool though. Got's to love them foorties Citeren Link naar opmerking Deel via andere websites More sharing options...
aw12345 Geplaatst June 30, 2012 Auteur Rapporteren Share Geplaatst June 30, 2012 I rolled mine outside today, the little girl was aching for fresh air and a tan Out in the sunlight Found some stickers in the mail, never asked for them. Thought that was a pretty cool gesture Difference between 37" tire and 40" tire 36.5" versus 39.5" Citeren Link naar opmerking Deel via andere websites More sharing options...
aw12345 Geplaatst June 30, 2012 Auteur Rapporteren Share Geplaatst June 30, 2012 Gots to built me a flex ramp some day out of a bunch of scrap steel This temp ramp building is for the birds, on the bright side looks like the sneakers will work and clear. Guess a quicky trip up Cleghorn is next Citeren Link naar opmerking Deel via andere websites More sharing options...
