REAL STRANGLER Geplaatst October 21, 2008 Rapporteren Share Geplaatst October 21, 2008 Hoi mannen, [ en natuurlijk dames...] hoe zet ik de indicator terug van een Grand uit 1993? vast bedankt, siert. Citeren Link naar opmerking Deel via andere websites More sharing options...
boris Geplaatst October 21, 2008 Rapporteren Share Geplaatst October 21, 2008 Hoi mannen, [ en natuurlijk dames...]hoe zet ik de indicator terug van een Grand uit 1993? vast bedankt, siert. Kun je dit niet met de OBD-scanner ? Door alle code's te wissen Citeren Link naar opmerking Deel via andere websites More sharing options...
Mitchell2.24v Geplaatst October 22, 2008 Rapporteren Share Geplaatst October 22, 2008 Nee, daarmee reset je niet de KM teller tot onderhoud. Perform ServiceThe message is displayed if "miles/kms to service" is 0, to indicate that regular service and maintenance is due. Refer to the Maintenance Schedules in this manual and perform the correspoiding service. To reset the counter, press the "Select" button momentarily, then press and hold the "Set" button for at least two seconds with the ignition On. Customize Your Vehicle Information Center Information can be displayed in U.S. or Metric. Press the US/M button on the Overhead Console to select the desired mode. Use the following steps to customize your Vehicle Information Center: 1. Press and hold the SET button while turning the ignition ON. The Center will display "Language" -- (whatever language was set during the last "Set" cycle). 2. Press the SELECT button to display the next language selection. You have the choice of English, French, German, Spanish, or Italian. Press the SET button to lock in your choice. 3. After step 2 has been completed the Center will change the screen to a 12 or 24-hour time cycle that you can choose between by pressing the SELECT button. 4. Pressing the SET button will lock your choice into the computer. 5. After step 4 has been completed the Center will display the service reminder mileage interval. If you choose to be reminded of service more often than 7,500 miles (3,000 km) you can change the mileage interval by pressing the SELECT button. It can be set to indicate mileage in 500 mile increments from 2,000 to 7,500 (or in 1,000km increments from 3,000km to 12,000km). 6. When you have reached the desired number press the SET button to store your choice in the computer and to return the display to normal operation. Misschien is dit iets voor een 'sticky'. Deze vraag komt regelmatig terug (ik heb 'm zelf al een aantal keer beantwoord)... Citeren Link naar opmerking Deel via andere websites More sharing options...
EJG Geplaatst October 22, 2008 Rapporteren Share Geplaatst October 22, 2008 ..Misschien is dit iets voor een 'sticky'. Deze vraag komt regelmatig terug (ik heb 'm zelf al een aantal keer beantwoord)... Zou je haast wel denken, maar dat is met de meeste vragen zo.... Jammer dat de meeste de zoekfunctie niet gebruiken Citeren Link naar opmerking Deel via andere websites More sharing options...
Mitchell2.24v Geplaatst October 22, 2008 Rapporteren Share Geplaatst October 22, 2008 Zou je haast wel denken, maar dat is met de meeste vragen zo....Jammer dat de meeste de zoekfunctie niet gebruiken Klopt, en er is al een sticky (besef ik nu)... Ik heb de tekst daar even in toegevoegd (klik) Citeren Link naar opmerking Deel via andere websites More sharing options...
RANDOMAN Geplaatst October 22, 2008 Rapporteren Share Geplaatst October 22, 2008 Bij mij moet je die knop gewoon een paar seconden ingedrukt houden en dan kan je zelf aangeven na hoieveel km je die servicebeurt wilt. Zit daar altijd per ongeluk aan als ik de klok weer eens goed moet zetten nadat de accu eraf is geweest.. Citeren Link naar opmerking Deel via andere websites More sharing options...
REAL STRANGLER Geplaatst October 22, 2008 Auteur Rapporteren Share Geplaatst October 22, 2008 Ok , bedankt Mitchell, dat werkte inderdaad. siert. PS, natuurlijk had ik al gezocht maar helaas niet gevonden. Citeren Link naar opmerking Deel via andere websites More sharing options...
Lumberjack Geplaatst October 22, 2008 Rapporteren Share Geplaatst October 22, 2008 Jammer dat de meeste de zoekfunctie niet gebruiken Ik weet overigens niet hoe het bij jullie gaat; maar de zoekfunctie werkt niet echt nauwkeurig. Verschillende keren een zoekopdracht gegeven maar "dan komt ie er toch niet uit". Citeren Link naar opmerking Deel via andere websites More sharing options...
