service indicator resetten
Nee, daarmee reset je niet de KM teller tot onderhoud.
Perform Service
The message is displayed if "miles/kms to service" is 0, to indicate that regular service and maintenance is due. Refer to the Maintenance Schedules in this manual and perform the correspoiding service. To reset the counter, press the "Select" button momentarily, then press and hold the "Set" button for at least two seconds with the ignition On.
Customize Your Vehicle Information Center
Information can be displayed in U.S. or Metric. Press the US/M button on the Overhead Console to select the desired mode.
Use the following steps to customize your Vehicle Information Center:
1. Press and hold the SET button while turning the ignition ON. The Center will display "Language" -- (whatever language was set during the last "Set" cycle).
2. Press the SELECT button to display the next language selection. You have the choice of English, French, German, Spanish, or Italian. Press the SET button to lock in your choice.
3. After step 2 has been completed the Center will change the screen to a 12 or 24-hour time cycle that you can choose between by pressing the SELECT button.
4. Pressing the SET button will lock your choice into the computer.
5. After step 4 has been completed the Center will display the service reminder mileage interval. If you choose to be reminded of service more often than 7,500 miles (3,000 km) you can change the mileage interval by pressing the SELECT button. It can be set to indicate mileage in 500 mile increments from 2,000 to 7,500 (or in 1,000km increments from 3,000km to 12,000km).
6. When you have reached the desired number press the SET button to store your choice in the computer and to return the display to normal operation.
Misschien is dit iets voor een 'sticky'. Deze vraag komt regelmatig terug (ik heb 'm zelf al een aantal keer beantwoord)...
..Misschien is dit iets voor een 'sticky'. Deze vraag komt regelmatig terug (ik heb 'm zelf al een aantal keer beantwoord)...
Zou je haast wel denken, maar dat is met de meeste vragen zo....
Jammer dat de meeste de zoekfunctie niet gebruiken :whistle:
