michel1972 Geplaatst November 12, 2010 Rapporteren Share Geplaatst November 12, 2010 (bewerkt) Diverse onderdelen voor CJ , XJ , YJ en TJ Nieuwe XJ CONTROL ARM DROP BRACKETS € 150,- Cherokee control arm relocation brackets are used to relocate the upper and lower control arms approximately 3" lower and 1/2" forward of their factory position. The reduction in control arm angle improves the lifted ride and handling substantially. Nieuwe SHACKLE XJ REAR BOOMERANG 1.5 inch lift € 50,- These shackles provide a 1.5 inch lift while giving XJ owners the ability to run a longer spring without damaging the body at the rear of the leaf spring. They feature greasable Zerk fittings, urethane bushings, and a durable black powdercoat finish. Each shackle is laser-cut from 3/16-inch steel plate and has MIG-welded seams for superior strength. Gebruikte TeraFlex High Steer System € 225,- The TeraFlex high steer system was originally designed to be used with our top of the line TJ Wrangler suspension system- the MAX-LCG. But we found that many Jeep®s with more than 5†of lift while still utilizing a trackbar system would benefit from a high steer solution. This kit will beef up the essential steering components of your Dana 30/44 front axle. The system includes a HD tie rod and drag link with one ton tie rod ends & tapered inserts, and the HD cast high steer knuckle. Fits These Vehicles 91-01 Jeep Cherokee (XJ) 97-06 Jeep Wrangler (TJ) 91-95 Jeep Wrangler (YJ) 04-06 Jeep Wrangler Unlimited (TJ) Gebruikte Yakima Bike Carrier € 75,- Geschikt voor meerdere fietsen op een amerikaans 2 inch hitch systeem. Rubicon Express 2 inch Lift Block € 25,- Blocks are an easy way to add height to a vehicle without increasing spring rates. Only use on rear axles with vehicles using a spring-over axle design Gebruikte Bestop Driver Side Seat Riser links en rechts samen € 70,- Compatible replacement seat risers & sliders are now available for CJ & '87-'95 Wrangler vehicles with worn-out seat hardware. Quadra-trac transfer case low range reduction unit + hendel € 150,- The basic version of the QuadraTrac is the BW 1305. This transfer case did not have a low range. However there was an optional low range of 2.57 for the QuadraTrac available, being attained through a bolt-on planetary reduction unit. This unit as an assembly was designated as the BW 1339 Nieuw de 2 Voorste Rugged Ridge 7" Fender Flare Set € 50,- Made from lightly textured thermo plastic like the original but UV treated to prevent "chalking". Adds an additional 3.75" inches of tire coverage over the stock 3.25" wide flares. Include front "dog leg" fender extensions. 4 Rancho shocks voor een lift van +/- 3 a 3.5 inch € 80,- 2 voorste shocks instelbaar in hardheid samen met de shock mount conversion November 12, 2010 bewerkt door michel1972 Citeren Link naar opmerking Deel via andere websites More sharing options...
michel1972 Geplaatst November 12, 2010 Auteur Rapporteren Share Geplaatst November 12, 2010 (bewerkt) Diverse onderdelen voor CJ , XJ , YJ en TJ Nieuwe XJ CONTROL ARM DROP BRACKETS € 150,- Cherokee control arm relocation brackets are used to relocate the upper and lower control arms approximately 3" lower and 1/2" forward of their factory position. The reduction in control arm angle improves the lifted ride and handling substantially. Gereserveerd Nieuwe SHACKLE XJ REAR BOOMERANG 1.5 inch lift € 50,- These shackles provide a 1.5 inch lift while giving XJ owners the ability to run a longer spring without damaging the body at the rear of the leaf spring. They feature greasable Zerk fittings, urethane bushings, and a durable black powdercoat finish. Each shackle is laser-cut from 3/16-inch steel plate and has MIG-welded seams for superior strength. Gebruikte TeraFlex High Steer System € 225,- The TeraFlex high steer system was originally designed to be used with our top of the line TJ Wrangler suspension system- the MAX-LCG. But we found that many Jeep®s with more than 5†of lift while still utilizing a trackbar system would benefit from a high steer solution. This kit will beef up the essential steering components of your Dana 30/44 front axle. The system includes a HD tie rod and drag link with one ton tie rod ends & tapered inserts, and the HD cast high steer knuckle. Fits These Vehicles 91-01 Jeep Cherokee (XJ) 97-06 Jeep Wrangler (TJ) 91-95 Jeep Wrangler (YJ) 04-06 Jeep Wrangler Unlimited (TJ) Gebruikte Yakima Bike Carrier € 75,- Geschikt voor meerdere fietsen op een amerikaans 2 inch hitch systeem. Gereserveerd Rubicon Express 2 inch Lift Block € 25,- Blocks are an easy way to add height to a vehicle without increasing spring rates. Only use on rear axles with vehicles using a spring-over axle design Gebruikte Bestop Driver Side Seat Riser links en rechts samen € 70,- Compatible replacement seat risers & sliders are now available for CJ & '87-'95 Wrangler vehicles with worn-out seat hardware. Quadra-trac transfer case low range reduction unit + hendel € 150,- The basic version of the QuadraTrac is the BW 1305. This transfer case did not have a low range. However there was an optional low range of 2.57 for the QuadraTrac available, being attained through a bolt-on planetary reduction unit. This unit as an assembly was designated as the BW 1339 Nieuw de 2 Voorste Rugged Ridge 7" Fender Flare Set € 50,- Made from lightly textured thermo plastic like the original but UV treated to prevent "chalking". Adds an additional 3.75" inches of tire coverage over the stock 3.25" wide flares. Include front "dog leg" fender extensions. 4 Rancho shocks voor een lift van +/- 3 a 3.5 inch € 80,- 2 voorste shocks instelbaar in hardheid samen met de shock mount conversion November 12, 2010 bewerkt door michel1972 Citeren Link naar opmerking Deel via andere websites More sharing options...
F.M Geplaatst November 12, 2010 Rapporteren Share Geplaatst November 12, 2010 die rancho shocks passen die ook op een cj Citeren Link naar opmerking Deel via andere websites More sharing options...
michel1972 Geplaatst November 12, 2010 Auteur Rapporteren Share Geplaatst November 12, 2010 die rancho shocks passen die ook op een cj Mijn cj kan alleen shocks kwijt die oog naar oog zijn. Citeren Link naar opmerking Deel via andere websites More sharing options...
cherokee'94 Geplaatst November 12, 2010 Rapporteren Share Geplaatst November 12, 2010 hallo, ik ben op zoek naar een set om mijn cherokee xj een lift te geven, maar kom er niet goed uit wat nou wat is. Zit hier iets bij waarmee ik mijn cherokee en lift kan geven van 1,5" tot 2" ? en dan zowel voor als achter. het is een cherokee xj uit '94. groet Rikkert Citeren Link naar opmerking Deel via andere websites More sharing options...
michel1972 Geplaatst November 12, 2010 Auteur Rapporteren Share Geplaatst November 12, 2010 hallo, ik ben op zoek naar een set om mijn cherokee xj een lift te geven, maar kom er niet goed uit wat nou wat is. Zit hier iets bij waarmee ik mijn cherokee en lift kan geven van 1,5" tot 2" ? en dan zowel voor als achter. het is een cherokee xj uit '94. groet Rikkert Goedendag, Er zaten 2 dingen bij die je cherokee xj van achteren een lift konden geven maar deze zijn al gereserveerd. probeer eens www.cherokeeparts.nl die heeft wel iets liggen voor een verhoging van 1.5 a 2 inch Citeren Link naar opmerking Deel via andere websites More sharing options...
michel1972 Geplaatst September 5, 2011 Auteur Rapporteren Share Geplaatst September 5, 2011 (bewerkt) Diverse onderdelen voor CJ , XJ , YJ en TJ Gebruikte TeraFlex High Steer System a € 200,- The TeraFlex high steer system was originally designed to be used with our top of the line TJ Wrangler suspension system- the MAX-LCG. But we found that many Jeeps with more than 5 inch of lift while still utilizing a trackbar system would benefit from a high steer solution. This kit will beef up the essential steering components of your Dana 30/44 front axle. The system includes a HD tie rod and drag link with one ton tie rod ends & tapered inserts, and the HD cast high steer knuckle. Fits These Vehicles 91-01 Jeep Cherokee (XJ) 97-06 Jeep Wrangler (TJ) 91-95 Jeep Wrangler (YJ) 04-06 Jeep Wrangler Unlimited (TJ) Gebruikte Yakima Bike Carrier a € 50,- Geschikt voor meerdere fietsen op een amerikaans 2 inch hitch systeem. Rubicon Express 2 inch Lift Block a € 25,- Blocks are an easy way to add height to a vehicle without increasing spring rates. Only use on rear axles with vehicles using a spring-over axle design Quadra-trac transfer case low range reduction unit + hendel a € 150,- The basic version of the QuadraTrac is the BW 1305. This transfer case did not have a low range. However there was an optional low range of 2.57 for the QuadraTrac available, being attained through a bolt-on planetary reduction unit. This unit as an assembly was designated as the BW 1339 September 5, 2011 bewerkt door michel1972 Citeren Link naar opmerking Deel via andere websites More sharing options...
michel1972 Geplaatst October 25, 2011 Auteur Rapporteren Share Geplaatst October 25, 2011 Diverse onderdelen voor CJ , XJ , YJ en TJ Gebruikte TeraFlex High Steer System a € 200,- The TeraFlex high steer system was originally designed to be used with our top of the line TJ Wrangler suspension system- the MAX-LCG. But we found that many Jeeps with more than 5 inch of lift while still utilizing a trackbar system would benefit from a high steer solution. This kit will beef up the essential steering components of your Dana 30/44 front axle. The system includes a HD tie rod and drag link with one ton tie rod ends & tapered inserts, and the HD cast high steer knuckle. Fits These Vehicles 91-01 Jeep Cherokee (XJ) 97-06 Jeep Wrangler (TJ) 91-95 Jeep Wrangler (YJ) 04-06 Jeep Wrangler Unlimited (TJ) Gebruikte Yakima Bike Carrier a € 50,- Geschikt voor meerdere fietsen op een amerikaans 2 inch hitch systeem. Rubicon Express 2 inch Lift Block a € 25,- Blocks are an easy way to add height to a vehicle without increasing spring rates. Only use on rear axles with vehicles using a spring-over axle design Quadra-trac transfer case low range reduction unit + hendel a € 150,- The basic version of the QuadraTrac is the BW 1305. This transfer case did not have a low range. However there was an optional low range of 2.57 for the QuadraTrac available, being attained through a bolt-on planetary reduction unit. This unit as an assembly was designated as the BW 1339 Uppie Citeren Link naar opmerking Deel via andere websites More sharing options...
maurice coolen Geplaatst October 25, 2011 Rapporteren Share Geplaatst October 25, 2011 TeraFlex High Steer System is dit ook voor de dana 44 volgens teraflex zie ik aleen de 30. Citeren Link naar opmerking Deel via andere websites More sharing options...
Roland Geplaatst October 25, 2011 Rapporteren Share Geplaatst October 25, 2011 PB gestuurd.. Roland. Citeren Link naar opmerking Deel via andere websites More sharing options...
michel1972 Geplaatst October 27, 2011 Auteur Rapporteren Share Geplaatst October 27, 2011 TeraFlex High Steer System is dit ook voor de dana 44 volgens teraflex zie ik aleen de 30. Volgens deze link is hij ook echt voor een dana 44 vooras maar ik kocht het voor mijn xj. http://www.quadratec.com/products/16990_06_07.htm Citeren Link naar opmerking Deel via andere websites More sharing options...
michel1972 Geplaatst October 27, 2011 Auteur Rapporteren Share Geplaatst October 27, 2011 Gereserveerd voor Roland Citeren Link naar opmerking Deel via andere websites More sharing options...
pedro.rr Geplaatst November 1, 2011 Rapporteren Share Geplaatst November 1, 2011 Heb je de 2inch lift blokken nog ? Citeren Link naar opmerking Deel via andere websites More sharing options...
pedro.rr Geplaatst November 2, 2011 Rapporteren Share Geplaatst November 2, 2011 Citeren Link naar opmerking Deel via andere websites More sharing options...
