Diverse Jeep Onderdelen
michel1972
Diverse onderdelen voor CJ , XJ , YJ en TJ
Nieuwe XJ CONTROL ARM DROP BRACKETS € 150,-
Cherokee control arm relocation brackets are used to relocate the upper and lower control arms approximately 3"
lower and 1/2" forward of their factory position. The reduction in control arm angle improves the lifted ride
and handling substantially.
Nieuwe SHACKLE XJ REAR BOOMERANG 1.5 inch lift € 50,-
These shackles provide a 1.5 inch lift while giving XJ owners the ability to run a longer spring without damaging the body at the rear of the leaf spring. They feature greasable Zerk fittings, urethane bushings, and a durable black powdercoat finish. Each shackle is laser-cut from 3/16-inch steel plate and has MIG-welded seams for superior strength.
Gebruikte TeraFlex High Steer System € 225,-
The TeraFlex high steer system was originally designed to be used with our top of the line TJ Wrangler suspension system- the MAX-LCG. But we found that many Jeep®s with more than 5†of lift while still utilizing a trackbar system would benefit from a high steer solution. This kit will beef up the essential steering components of your Dana 30/44 front axle. The system includes a HD tie rod and drag link with one ton tie rod ends & tapered inserts, and the HD cast high steer knuckle.
Fits These Vehicles
91-01 Jeep Cherokee (XJ)
97-06 Jeep Wrangler (TJ)
91-95 Jeep Wrangler (YJ)
04-06 Jeep Wrangler Unlimited (TJ)
Gebruikte Yakima Bike Carrier € 75,-
Geschikt voor meerdere fietsen op een amerikaans 2 inch hitch systeem.
Rubicon Express 2 inch Lift Block € 25,-
Blocks are an easy way to add height to a vehicle without increasing spring rates. Only use on rear axles with vehicles using a spring-over axle design
Gebruikte Bestop Driver Side Seat Riser links en rechts samen € 70,-
Compatible replacement seat risers & sliders are now available for CJ & '87-'95 Wrangler vehicles with worn-out seat hardware.
Quadra-trac transfer case low range reduction unit + hendel € 150,-
The basic version of the QuadraTrac is the BW 1305. This transfer case did not have a low range. However there was an optional low range of 2.57 for the QuadraTrac available, being attained through a bolt-on planetary reduction unit. This unit as an assembly was designated as the BW 1339
Nieuw de 2 Voorste Rugged Ridge 7" Fender Flare Set € 50,-
Made from lightly textured thermo plastic like the original but UV treated to prevent "chalking". Adds an additional 3.75" inches of tire coverage over the stock 3.25" wide flares. Include front "dog leg" fender extensions.
4 Rancho shocks voor een lift van +/- 3 a 3.5 inch € 80,-
2 voorste shocks instelbaar in hardheid samen met de shock mount conversion
bewerkt door michel1972
Gereserveerd Nieuwe SHACKLE XJ REAR BOOMERANG 1.5 inch lift € 50,-
Fits These Vehicles
Gereserveerd Rubicon Express 2 inch Lift Block € 25,-
hallo,
ik ben op zoek naar een set om mijn cherokee xj een lift te geven, maar kom er niet goed uit wat nou wat is. Zit hier iets bij waarmee ik mijn cherokee en lift kan geven van 1,5" tot 2" ? en dan zowel voor als achter. het is een cherokee xj uit '94.
groet Rikkert
hallo,
groet Rikkert
Goedendag,
Er zaten 2 dingen bij die je cherokee xj van achteren een lift konden geven maar deze zijn al gereserveerd.
probeer eens www.cherokeeparts.nl die heeft wel iets liggen voor een verhoging van 1.5 a 2 inch
  • 9 months later...
Gebruikte TeraFlex High Steer System a € 200,-
The TeraFlex high steer system was originally designed to be used with our top of the line TJ Wrangler suspension system- the MAX-LCG. But we found that many Jeeps with more than 5 inch of lift while still utilizing a trackbar system would benefit from a high steer solution. This kit will beef up the essential steering components of your Dana 30/44 front axle. The system includes a HD tie rod and drag link with one ton tie rod ends & tapered inserts, and the HD cast high steer knuckle.
Fits These Vehicles
Gebruikte Yakima Bike Carrier a € 50,-
Rubicon Express 2 inch Lift Block a € 25,-
Quadra-trac transfer case low range reduction unit + hendel a € 150,-
  • 1 month later...
Fits These Vehicles
Uppie
