richtingaanwijzers
RobB
De richtingaanwijzers doen het opeens niet meer (voor en achter). De alarmlichten wel.
Alle verdere functies van de stuurschakelaar (ruitenwissers, etc) zijn wel o.k.
Heb vandaag wel even aan de draadjes van de cruisecontrol zitten rommelen (oorzakelijk verband?). Die doet het namelijk al tijden niet meer.
Zekering voor de richtingaanwijzers heb ik gecheckt, was in orde.
Wat kan het zijn?
Alvast bedankt!
RobB
TURN SIGNALS & HAZARD FLASHERS
1988 Jeep Cherokee
1988 Turn Signal & Hazard Light Systems
JEEP
DESCRIPTION
Turn signals and hazard flashers systems use a common turn
signal/hazard light switch assembly mounted within upper steering
column housing.
FLASHER LOCATIONS
Hazard
Mounted on fuse block.
Turn Signal
TROUBLE SHOOTING
NOTE: Following trouble shooting is only information available
from manufacturer.
Hazard Lights (Comanche, Cherokee & Wagoneer)
If lights do not come on with hazard switch turned on, check
hazard/stop light fuse by operating stop lights. If fuse is okay,
check turn signal flasher, turn signal/hazard switch, and related
wiring. If only one hazard light does not work, check bulb.
Turn Signals (Comanche, Cherokee & Wagoneer)
If all turn signals do not work, check turn/back-up light
fuse by operating back-up lights. If fuse is okay, check turn signal
flasher, turn signal/hazard switch, and related wiring. If only one
turn signal does not work, check bulb.
TESTING
from manufacturer.
Hazard Indicators (Wrangler)
1) Turn ignition and hazard warning switch "ON". Check for
pulsating voltage at Light Blue (left indicator) and Dark Blue (right
indicator) wires. If voltage is present, go to next step. If voltage
is not present, replace turn signal switch.
2) Remove bulbs for turn signal indicators. Measure
resistance across bulb terminals. If resistance is zero ohms, replace
light bulb(s). If resistance readings are not zero ohms, go to next
step.
3) Check for pulsating voltage at battery side of bulb
sockets. If voltage is present, go to next step. If voltage is not
present, repair open circuit between socket and turn signal switch
steering column connector.
4) Turn ignition off and check resistance on ground side of
bulb sockets. If resistance is zero ohms, hazard indicator circuit is
okay. If resistance reading is not zero ohms, repair open in ground
circuit.
Hazard Lights (Wrangler)
Het relais voor de richtingaanwijzers cit op je zekeringblok. Links boven zit een rond "potje", dat is 'm!
Onderaan rechts zit er ook één, die is voor de alarmlichten.
Kijk ook even naar de connector van de richtingaanwijzerschakelaar, Das een lange platte stekker, tegen je stuurkolom. Als die niet goed in elkaar zit, werkt het ook niet meer.
Ik heb nog even wat schema's bekeken... Er zijn 2 zekeringen: één in je zekeringkast binnen, en één in je PDC ( zwarte kast bij de accu).
Verder zit er niets meer in het systeem dan de "flasher"( relais) en de schakelaar. De alarmlichtenschakelaar onderbreekt ook het normale richtingaanwijzersysteem ( 2x woordwaarde wink.gif ). Kijk dus even of die misschien niet goed terugkomt.
succes!
  • 3 months later...
Ik heb het zelfde probleem allen bij een YJ, mijn idee was wel dat de/het relais niet goed was, het begon met onregelmatig knipperen en vanochtend bleef hij een minuut branden en was ongeveer 0.5 seconde uit, maar vanmiddag bleven ze gewoon branden........
oke na dit verhaaltje mijn vraag: hoe krijg ik in godsnaam dat relais er uit????? het zijn twee stalen "bakjes" één voor de alarmlichten (die gewoon wel werken) en één voor de knipperlichten en niet zoals ik gewent ben zo'n kunststof ding met pootjes aan de onderkant....
ik heb al geprobeerd em naar boven te schuiven maar nou doen mn knipperlichten het helemaal niet meer, ik hoop niet dat nou mn zekeringen kast kapot is ohmy.gif
ik ben er uit... en het relais ook tongue.gif het is inderdaad "gewoon" trekken.... net als zo'n "normaal" relais als ik al kende, maar het gaat wel zwaar en ik wil natuurlijk een beetje (te) voorzichtig want ik wil niet die hele zekeringenkast in mn handen houden hahaha
ik heb de relais gewisseld (die van de alarmlichten zit er nu in) en dat werkt helemaal goed!! nu dus een nieuwe kopen en dan doen mn alarmlichten het ook weer!
  • 3 weeks later...
Daar ben ik weer! Nadat ik een ander relais in de zekeringkast heb gezet deden de knipperlichten het weer goed. Althans, tot gisteren. Als ik de stuurschakelaar aanzet, knipperen ze eerst normaal, dan even heel snel en vervolgens weer normaal.
Het vervangen relais was volgens mij wel al eerder gebruikt...(De garagist plukte het relais uit een doos met gebruikte onderdelen; ik hoefde er ook niets voor te betalen)
Weer vervangen (voor nieuw) of is hier toch iets anders aan de hand?
Alvast bedankt voor de reactie(s)
RobB
