aw12345 Geplaatst October 14, 2012 Auteur Rapporteren Share Geplaatst October 14, 2012 Started on my buggy cage mod, looks good to me This side is next Citeren Link naar opmerking Deel via andere websites More sharing options...
aw12345 Geplaatst October 30, 2012 Auteur Rapporteren Share Geplaatst October 30, 2012 Spend some time yesterday and today, farting around with my buggy project. Got the drivers side angled in like I wanted yesterday. Today picked up a stick of 1.5' x 0.120 wall tubing to fix the back end. Cut some crossmember pieces out and cut 2 old driveshafts so I can turn them into one that will fit the rear. Since the slip yoke is in the trans it's going to take a bit of doing to get the length right. Now that I have room between the frame rails I can start thinking about a crossmember that will clear the rear driveshaft and braces the rear control arm frame mounts, actually going to try and tie this thing to the front lower control arms also. Will make for a nice base for the belly pan. Going to have to make it so I can run 2 exhaust pipes to the back and there is a good change that I will run 2 tubes to the back for a rear mount radiator. Unless I can use a TJ radiator that I have, that one seems to fit better than the stock Nissan radiator. It will allow me to mount it higher so I can cut and raise the front of the frame for clearance for the steering ram and high steer. Citeren Link naar opmerking Deel via andere websites More sharing options...
aw12345 Geplaatst November 5, 2012 Auteur Rapporteren Share Geplaatst November 5, 2012 Started to put the grinder in the rear suspension to give it my touch. Hope to make some progress with it today. Subtle difference Citeren Link naar opmerking Deel via andere websites More sharing options...
aw12345 Geplaatst November 5, 2012 Auteur Rapporteren Share Geplaatst November 5, 2012 Moving right along Was doing some brain storming and it looks like I am going to use 2 piece rear driveshaft. Will make me feel better about the slip yoke in the rear of the trans, it will also allow me to built a crossmember between the frame side rear control arm mounts and incorporate the intermediate driveshaft support bearing in it. Then use a regular driveshaft with a slip yoke for the rear shaft. That way I can for one keep the drive line angles at a reasonable. level Nor have to worry as much about the yoke sliding in and out of the transmission. Citeren Link naar opmerking Deel via andere websites More sharing options...
aw12345 Geplaatst November 6, 2012 Auteur Rapporteren Share Geplaatst November 6, 2012 Done screwing around with it for the day, Looking better, still has several inches of travel left 1 Citeren Link naar opmerking Deel via andere websites More sharing options...
Bleek Geplaatst November 6, 2012 Rapporteren Share Geplaatst November 6, 2012 Citeren Link naar opmerking Deel via andere websites More sharing options...
aw12345 Geplaatst November 8, 2012 Auteur Rapporteren Share Geplaatst November 8, 2012 (bewerkt) Thanks, lots more to do Probably will have it done, before Otto ever finishes his Grand Cherokee November 8, 2012 bewerkt door aw12345 1 Citeren Link naar opmerking Deel via andere websites More sharing options...
EJG Geplaatst November 8, 2012 Rapporteren Share Geplaatst November 8, 2012 Dat is niet zo moeilijk, IEDEREEN krijgt zijn jeep af, voordat Otto klaar is. 1 Citeren Link naar opmerking Deel via andere websites More sharing options...
Bleek Geplaatst November 8, 2012 Rapporteren Share Geplaatst November 8, 2012 Zelfs ikke Citeren Link naar opmerking Deel via andere websites More sharing options...
aw12345 Geplaatst November 8, 2012 Auteur Rapporteren Share Geplaatst November 8, 2012 So git er done Otto Citeren Link naar opmerking Deel via andere websites More sharing options...
Ogdak Geplaatst November 9, 2012 Rapporteren Share Geplaatst November 9, 2012 There will be a time for everything. 1 Citeren Link naar opmerking Deel via andere websites More sharing options...
aw12345 Geplaatst November 10, 2012 Auteur Rapporteren Share Geplaatst November 10, 2012 Dat is waar Otto, heb met mijn buggie ook geen haast, is een project om me zoet te houden als ik niet in het terein aan het crossen ben. :lol: Citeren Link naar opmerking Deel via andere websites More sharing options...
aw12345 Geplaatst November 12, 2012 Auteur Rapporteren Share Geplaatst November 12, 2012 Well today went from wood tinkering to steel tinkering. First made wife's day, hung the new door she has been wanting for a while. Planed and cut it to size last week, did a bit of fiddeling with it today and it fits like a glove. Then rolled my buggy outside and started playing with some ideas for a driveshaft. Seems to me this will work, will allow a crossmember between the lower control arms and not restrict rear axle travel. Going to add a bit of tube to the rear cage also kinda like this from both sides Then get some more tube and bend it so the rear has a bottom, kinda like this Here is the rough bodywork on Tinkertoy's hood, it is somewhat back to it's original shape Citeren Link naar opmerking Deel via andere websites More sharing options...
aw12345 Geplaatst November 12, 2012 Auteur Rapporteren Share Geplaatst November 12, 2012 Should have the tube work for the back all done today, starting to like where the whole thing is going. Bought some 4"x4" square tubing 1/4" wall to built the crossmember and driveshaft support from. Citeren Link naar opmerking Deel via andere websites More sharing options...
aw12345 Geplaatst November 13, 2012 Auteur Rapporteren Share Geplaatst November 13, 2012 Great job on the door(impressing). Can't wait to see how the buggy works. Neither can I' date=' I'll just keep pecking away at it and eventually it will be done. By the way Curtis if you want a Hammer beater that has actually a fair amount of nice stuff in it, check this one out http://inlandempire.craigslist.org/cto/3357426944.html Coilovers and stickies what more could you possibly want for that amount of money. Anyway back to the scheduled program, got the crossmember tacked in now it needs some notching and French love so the primary drive shaft kind of runs through it, with a bit of work I should be able to get decent driveline angles, the thing is also [lenty stout to gusset the frame side control arm mounts too. Rear tube work is pretty much done, I am happy with it. Bottom of the frame is 24" of the ground and I am pretty happy with how it sits now and where the air shock travel is at. [img']http://i131.photobucket.com/albums/p289/aartw12345/buggy%20project/sylvestor011.jpg Citeren Link naar opmerking Deel via andere websites More sharing options...
aw12345 Geplaatst November 14, 2012 Auteur Rapporteren Share Geplaatst November 14, 2012 Looks like I can make this driveline setup happen, going to have to find some U joints and I can weld the whole shebang together. Citeren Link naar opmerking Deel via andere websites More sharing options...
aw12345 Geplaatst November 18, 2012 Auteur Rapporteren Share Geplaatst November 18, 2012 Started mocking up where the steering ram has to go. Where the piece of angle iron sits is what needs to become the bottom of the frame Citeren Link naar opmerking Deel via andere websites More sharing options...
aw12345 Geplaatst November 19, 2012 Auteur Rapporteren Share Geplaatst November 19, 2012 Oops, something went missing Something went back on. It even sports a Jeep TJ radiator, fits it perfectly. Has enough room now for a double ended steering ram. Citeren Link naar opmerking Deel via andere websites More sharing options...
EJG Geplaatst November 19, 2012 Rapporteren Share Geplaatst November 19, 2012 Krijgt het ook nog een Jeep look ? Citeren Link naar opmerking Deel via andere websites More sharing options...
aw12345 Geplaatst November 19, 2012 Auteur Rapporteren Share Geplaatst November 19, 2012 We zullen zien, net wat me bui is en wat ik vind aan onderdelen Citeren Link naar opmerking Deel via andere websites More sharing options...
aw12345 Geplaatst November 23, 2012 Auteur Rapporteren Share Geplaatst November 23, 2012 Fiddled around with the rear suspension some, looks like that is going to live the way it is. Going to plug the numbers in and if that comes out as happy as it looks I'll leave that alone. Just going to truss the rear axle some and gusset the frame side mounts to the crossmember add a few more pieces of tube and the back should be officially done. Next on the list is to mount the radiator and trans cooler. Then on to some bracing of the front tubing Citeren Link naar opmerking Deel via andere websites More sharing options...
aw12345 Geplaatst November 24, 2012 Auteur Rapporteren Share Geplaatst November 24, 2012 lowrider Plenty of room for a Taurus or MK7 fan Jeep radiator looks right at home, found a spot for the trans cooler also Citeren Link naar opmerking Deel via andere websites More sharing options...
aw12345 Geplaatst November 25, 2012 Auteur Rapporteren Share Geplaatst November 25, 2012 I really am starting to like the look of the front of this thing. Just haven't got a clue where I will hide the winch or how big a winch I'll need Would be cool to stuff something like a Warn 6000 lbs winch behind the radiator Citeren Link naar opmerking Deel via andere websites More sharing options...
aw12345 Geplaatst November 25, 2012 Auteur Rapporteren Share Geplaatst November 25, 2012 Got pretty much the front tubed out Citeren Link naar opmerking Deel via andere websites More sharing options...
aw12345 Geplaatst November 25, 2012 Auteur Rapporteren Share Geplaatst November 25, 2012 Sometimes it's just nice to sit back and look at a part that's semi finished Citeren Link naar opmerking Deel via andere websites More sharing options...
