J-20 6 Wheeler
ROELAND
Een tip uit de UK voor de liefhebbers B)
Not mine: remember that one on ebay a few months ago? Well the buyer contacted me today to see if I was interested in buying it, and im not, but here is the write up he intends to use on ebay in a few weeks, drop me a PM if you want his mob:
> Jeep J20 Recovery Vehicle Pickup Project Camper, etc
> Hello and welcome to my advert for a rare and unusual project with
> LOADS of potential. See the end of the ad for suggestions.
> Firstly, please don't underestimate how big this vehicle is. It's
> approximately 20 feet long, approximately eight feet high (plus the
> beacon) and about the width of a van, so if you only have a short
> drive then don't even read any further. Oh, it also weighs about three
> tons, so you'll need a substantial jack, too !
> I bought this vehicle on an impulse a few weeks ago. There wasn't time
> to go and see it before the auction ended so I took the risk and
> bought it blind. Now it's standing on my drive I realise that maybe
> it might be not the sort of thing I'm looking for, so I've decided to offer it for
sale.
> If it doesn't sell in a few weeks then I'm going to bite the bullet
> and do it up myself.
> The previous owner was somewhat economical with his description of the
> vehicle but I'm going to be as honest as I can so you know exactly
> what it is you're buying.
> The Jeep was originally a fire tender in service with East Sussex Fire
> Brigade. Since then it has been owned by enthusiasts, reputedly spent
> some time at Heathrow airport and was finally bought by a garage in
> London that was going to use it as an air cushion rescue vehicle (i.e.
> inflating big air bags to get trucks that have fallen over back on
> their wheels). It was originally red, and you can see a picture of how
> it would have originally looked, here:
> The vehicle is based on a right-hand-drive 1984 American Jeep J20
> chassis which has been lengthened to take an additional trailing axle.
> Please be aware of this: it's four wheel drive, not six. The back
> wheels aren't driven and just trail along for the ride. I haven't
> tested the four wheel drive yet.
> It's driven by an American Motors Corporation (AMC) 360 cubic inch
> (about
> 5.9 litre) V8 petrol engine with a single Motorcraft carb, which
> drives through a three speed automatic gearbox.
> The front of the vehicle is a separate steel typical pickup cab which
> will seat three (maybe even two adults and two small children?) on a
> single bench seat. The rear is a mainly aluminium body which was
> specially built by Angloco. It has aluminium roller shutter doors and
> a couple of locker-type doors at the rear, and is fitted out with shelving, etc.
> Apparently it was an expensive vehicle in its day (£18750 for the
> chassis and £12675 for the Angloco body, apparently).
> The rear also contains a large Hydrovane compressor (not tested) and a
> reel of hose to connect to the compressor (not tested). There is a
> stemlight beacon on the top of the body which apparently raises to
> quite a height and has floodlights underneath, but the wiring seems to
> have been disconnected and I have not tested this.
> Condition-wise, it isn't too bad for a twenty six year old vehicle. It
> has obviously stood for some time (the mileage is a very low 51000
> approx) and it needs a bit of work, but it is by no means a shed. The
> pickup cab has a couple of rust holes in it and the aluminium rear
> body could do with a bit of attention in places. All the shutters roll
> up and down but the driver's side window will not wind down (don't
> worry - it's manual wind not electric so should be cheap to fix). The
> paint is flat and a bit scabby in places and some of the decals on it
> are faded. In reality it could do with a re-spray. One of the wing
> mirrors is missing but the previous owner still has it and is supposed to be
sending it to me in the next few days.
> Underneath it seems to be fine and the massive chassis and leaf
> springs are in very solid condition. The bull bars on the front are
> huge! The tyres are good. Inside the cab the vinyl seats and door
> cards are in good condition. The headlining and the sun visors are
> present but have been taken out of the vehicle.
> The engine needs a little work but nothing major. The engine smokes on
> startup which could indicate that the valve stem seals have hardened
> with the vehicle standing unused for long periods. Alternately it
> could be just the fuel that has deteriorated in the tank, as I know it
> has been there for at least a couple of years. When the engine warms
> the smoke does clear. I've had the engine looked at by tuning
> specialists and they reported that there was a slight air leak from
> the carb-to-engine gasket but the mixture has been adjusted to
> compensate for this. The oil pressure is good and emissions are low.
> I've driven the vehicle over a short distance and there seems to be a
> fuelling issue because the engine will die and cut out periodically,
> but again this could be partly due to the old fuel in the tank. I plan
> to pump out the old fuel and put in some fresh to see if it makes the
> vehicle run any better. The battery is brand new.
> "Jesus !", you might say, "What could I possibly do with a vehicle
> like this...?" Well, lots of things, really. If you didn't want to
> restore it to its former glory and take it to shows you could:
> * Use it as a recovery vehicle
> * Take off the back and fit a pick-up body or use it as a 'fifth wheel'.
> It would make a great pickup and you'd probably get quite a bit of
> money for the scrap aluminium, compressor, etc.
> * Use it as a fruit and veg delivery/sales van
> * Start your own gardening business.
> * Start a bouncy castle hire business (using the compressor ?)
> * Make an expedition vehicle or camper van
> * Turn it into a mobile disco using the stemlight (Just an idea...)
> * Someone even suggested it would make a good Ghostbusters vehicle !
> I'm sure you can think of others. As I said earlier, if it doesn't
> sell in a few weeks then I'm going to do something like this with it.
> Unfortunately there is currently no paperwork with the vehicle but
> I've been in touch with a previous owner and they are sending some
> through. If it doesn't materialise within the week I will apply for a
> new V5 and SORN in my name. The vehicle doesn't have tax or MOT so
> would have to be transported on the back of a car transporter. I can
> recommend a good delivery company if required.
> I think that's about as much as I can tell you at the moment. You now
> know much more than I did when I bought it a few weeks ago.
> If you have any more questions then please get in touch and I'll do my
> best to answer them. If you are interested in the vehicle then I'd say
> that it is essential that you come and look at it before you buy.
> Please contact me to arrange a convenient time. Don't leave it too
> long, though, as I'll withdraw it from sale if it doesn't sell in a
> few weeks and start work on it myself.
£ 1250,--
> Lee
post-1492-0-60872100-1288648224_thumb.jp
bewerkt door Ogdak
link aangepast
