kieken10 Geplaatst February 16, 2022 Auteur Rapporteren Share Geplaatst February 16, 2022 45 minuten geleden zei Ab: Uit de handleiding van de Uconnect 5: After pressing the "Display" button on the touchscreen the following settings will be available. Display Mode: When in this display you may select the "Auto" or "Manual" display settings. To change Mode status, press and release the "Auto" or "Manual" button on the touchscreen. Then press the arrow back button on the touchscreen. NOTE: When Day or Night is selected for the Display Mode, the usage of the Parade Mode feature will cause the radio to activate the Display Brightness Day control even though the headlights are on. Display Brightness With Headlights ON: When in this display, you may select the overall screen brightness with the headlights on. Adjust the brightness with the "+" and "-" setting buttons on the touchscreen or by selecting any point on the scale between the "+" and "-" buttons on the touchscreen. NOTE: To make changes to the Display Brightness with Headlights ON setting, the headlights must be on and the interior dimmer switch must not be in the party or parade positions. Display Brightness With Headlights OFF: When in this display, you may select the overall screen brightness with the headlights off. Adjust the brightness with the "+" and "-" setting buttons on the touchscreen or by selecting any point on the scale between the "+" and "-" buttons on the touchscreen. NOTE: To make changes to the Display Brightness with Headlights OFF setting, the headlights must be off and the interior dimmer switch must not be in the party or parade positions. En nog een filmpje, bij 0:40 display is niet dezelfde het is dit zoals filmpje Citeren Link naar opmerking Deel via andere websites More sharing options...
Ab Geplaatst February 16, 2022 Rapporteren Share Geplaatst February 16, 2022 1 hour ago, kieken10 said: display is niet dezelfde het is dit zoals filmpje Ja, en wat zegen ze in jou filmpje bij 13:00 en verder? Display settings en brightness, is gelijk als wat in de manual staat, in mijn vorige post..... Toch maar even terug naar de dealer denk ik mocht dit bij jou niet aanwezig zijn. Citeren Link naar opmerking Deel via andere websites More sharing options...
kieken10 Geplaatst February 16, 2022 Auteur Rapporteren Share Geplaatst February 16, 2022 (bewerkt) 29 minuten geleden zei Ab: Ja, en wat zegen ze in jou filmpje bij 13:00 en verder? Display settings en brightness, is gelijk als wat in de manual staat, in mijn vorige post..... Toch maar even terug naar de dealer denk ik mocht dit bij jou niet aanwezig zijn. ok , ik heb het probleem dat ik het niet klaar krijg als lichten aangaan ik zou dezelfde lichtsterkte willen zoals overdag zelfs in manueel February 16, 2022 bewerkt door kieken10 Citeren Link naar opmerking Deel via andere websites More sharing options...
Ab Geplaatst February 16, 2022 Rapporteren Share Geplaatst February 16, 2022 Dus het is er wel, maar doet niet wat je wilt? Typisch Jeep! 😄 Citeren Link naar opmerking Deel via andere websites More sharing options...
kieken10 Geplaatst February 17, 2022 Auteur Rapporteren Share Geplaatst February 17, 2022 16 uur geleden zei Ab: Dus het is er wel, maar doet niet wat je wilt? Typisch Jeep! 😄 idd doet niet wat ik wil kan het niet zetten gelijk overdag snelheidsbordherkening laat ook zeeeer erg de wensen over, werkt ook niet zoals in mijn peugeot Citeren Link naar opmerking Deel via andere websites More sharing options...
Ab Geplaatst February 17, 2022 Rapporteren Share Geplaatst February 17, 2022 1 hour ago, kieken10 said: idd doet niet wat ik wil kan het niet zetten gelijk overdag snelheidsbordherkening laat ook zeeeer erg de wensen over, werkt ook niet zoals in mijn peugeot Nee, is ook logisch, Peugeot is PSA, Jeep is FCA. Stellantis heeft nog niet veel gelijk getrokken..... Citeren Link naar opmerking Deel via andere websites More sharing options...
kieken10 Geplaatst February 19, 2022 Auteur Rapporteren Share Geplaatst February 19, 2022 Op 17/2/2022 om 12:36 PM zei Ab: Nee, is ook logisch, Peugeot is PSA, Jeep is FCA. Stellantis heeft nog niet veel gelijk getrokken..... vind ik toch erg voor een auto met dit prijskaartje, had ik het geweten allemaal..................................... Citeren Link naar opmerking Deel via andere websites More sharing options...
REAL STRANGLER Geplaatst February 19, 2022 Rapporteren Share Geplaatst February 19, 2022 Omdat ik denk dat Ab gelijk heeft, mijn advies.... schrijf een keurig kort mailtje met vermelding van je VIN naar de importeur. Als dat niet werkt stuur je het naar de klantenservice in de USA. Natuurlijk is die lichtsterkte in te stellen, denk ik. Succes, Siert. Citeren Link naar opmerking Deel via andere websites More sharing options...
kieken10 Geplaatst February 19, 2022 Auteur Rapporteren Share Geplaatst February 19, 2022 4 uur geleden zei REAL STRANGLER: Omdat ik denk dat Ab gelijk heeft, mijn advies.... schrijf een keurig kort mailtje met vermelding van je VIN naar de importeur. Als dat niet werkt stuur je het naar de klantenservice in de USA. Natuurlijk is die lichtsterkte in te stellen, denk ik. Succes, Siert. Beste, je kan ze wel instellen maar als het donker word buiten gaat hij over in nachtstand en dit kan ik niet beletten reeds jeep belgie aangesproken , maar werd doorverwezen naar garage en daar houden ze vol dat dit niet kan grtn Citeren Link naar opmerking Deel via andere websites More sharing options...
stephan Geplaatst February 20, 2022 Rapporteren Share Geplaatst February 20, 2022 De verlichting in je tellerbak zal ook dimmen naar de nachtstand als buiten donker wordt denk ik. Ik denk dat als je de tellers minder laat dimmen dit ook effect heeft op je scherm. Maw probeer eens of je de tellerbak kunt instellen Citeren Link naar opmerking Deel via andere websites More sharing options...
kieken10 Geplaatst February 20, 2022 Auteur Rapporteren Share Geplaatst February 20, 2022 4 uur geleden zei stephan: De verlichting in je tellerbak zal ook dimmen naar de nachtstand als buiten donker wordt denk ik. Ik denk dat als je de tellers minder laat dimmen dit ook effect heeft op je scherm. Maw probeer eens of je de tellerbak kunt instellen neen ook al geprobeerd , gaat niet navigatiescherm gaat steeds over op donker Citeren Link naar opmerking Deel via andere websites More sharing options...
Vsk996 Geplaatst February 21, 2022 Rapporteren Share Geplaatst February 21, 2022 Toch denk ik dat je het daar moet zoeken. Heb het zaterdag (in het donker) geprobeerd bij mij - is wel een ander model Jeep maar ik vermoed dat al die modules op dezelfde manier werken. Interieurverlichting gaat aan door schakelaar helemaal 'naar boven' te draaien - je 'passeert' een klik en de interieurverlichting gaat aan met gesloten deuren (was zo bij mijn Jk, bij mijn JL en nu ook bij de JT - ik neem dus aan dat het bij alle modellen zo zal zijn) Vanuit deze stand 1 klikje terugdraaien en de 'heldere' display wordt behouden met koplampen aan en uit - zodra je verder dimt gaat de display met koplampen uit naar de andere stand Citeren Link naar opmerking Deel via andere websites More sharing options...
kieken10 Geplaatst February 21, 2022 Auteur Rapporteren Share Geplaatst February 21, 2022 2 uur geleden zei Vsk996: Toch denk ik dat je het daar moet zoeken. Heb het zaterdag (in het donker) geprobeerd bij mij - is wel een ander model Jeep maar ik vermoed dat al die modules op dezelfde manier werken. Interieurverlichting gaat aan door schakelaar helemaal 'naar boven' te draaien - je 'passeert' een klik en de interieurverlichting gaat aan met gesloten deuren (was zo bij mijn Jk, bij mijn JL en nu ook bij de JT - ik neem dus aan dat het bij alle modellen zo zal zijn) Vanuit deze stand 1 klikje terugdraaien en de 'heldere' display wordt behouden met koplampen aan en uit - zodra je verder dimt gaat de display met koplampen uit naar de andere stand beste ik snap niet welke knoppen je moet gebruiken, eventueel een foto aub Citeren Link naar opmerking Deel via andere websites More sharing options...
Ab Geplaatst February 21, 2022 Rapporteren Share Geplaatst February 21, 2022 Verlichting instellingen zijn per gebruikersprofiel in te stellen, misschien dat het daar niet goed gaat? Citeren Link naar opmerking Deel via andere websites More sharing options...
kieken10 Geplaatst February 21, 2022 Auteur Rapporteren Share Geplaatst February 21, 2022 18 minuten geleden zei Ab: Verlichting instellingen zijn per gebruikersprofiel in te stellen, misschien dat het daar niet goed gaat? hij staat bij mij op 10 en dan heb ik nachtscherm, verminderen kan ik nog dan zie bijna niets meer Citeren Link naar opmerking Deel via andere websites More sharing options...
