Arjanw Geplaatst May 17, 2019 Rapporteren Share Geplaatst May 17, 2019 Splinternieuwe schokbrekers voor Jeep Cherokee, Wrangler TJ en LJ.Skyjacker Black Max series shocks uses foam-cell technology. When the shock heats up the foam-cell compresses to compensate for oil expansion which maintains consistent performance even in most extremely temperatures. This kind of solution also eliminates unnecessary air inside the shocks which allows it to mount in 180 degrees. Thanks to the special high temperature oil shock retains viscosity of oil in all conditions. Black Max series shocks are designed for most demanding users. Finished in phenomenal black color that will make your Jeep Wrangler TJ/LJ look fantastic! Advanced Foam-Cell Technology Vehicle Specific Multi-Stage Valving Increased Fluid Capacity for MAX Heat Dissipation Directional Mounting Construction ensures solid contact between tire and road Twin Tube Construction Chrome Plated Shaft Sintered Iron Piston Black Boot Included Technical Data:Collapsed Length(cm): 37Extended Length(cm): 63 Forumprijs €60,- Link naar opmerking Deel via andere websites More sharing options...
Arjanw Geplaatst August 21, 2019 Auteur Rapporteren Share Geplaatst August 21, 2019 Up! Link naar opmerking Deel via andere websites More sharing options...
Arjanw Geplaatst September 30, 2019 Auteur Rapporteren Share Geplaatst September 30, 2019 Op 21/8/2019 om 1:20 PM zei Arjanw: Up! Up! Link naar opmerking Deel via andere websites More sharing options...
Arjanw Geplaatst November 13, 2019 Auteur Rapporteren Share Geplaatst November 13, 2019 €50,- dan maar....🙄 Link naar opmerking Deel via andere websites More sharing options...
Arjanw Geplaatst January 2, 2020 Auteur Rapporteren Share Geplaatst January 2, 2020 Up! Link naar opmerking Deel via andere websites More sharing options...
Arjanw Geplaatst May 2, 2020 Auteur Rapporteren Share Geplaatst May 2, 2020 Misschien verkoop ik ze wel als ik betere foto's plaats? Link naar opmerking Deel via andere websites More sharing options...
Arjanw Geplaatst May 17, 2020 Auteur Rapporteren Share Geplaatst May 17, 2020 Verkocht! Link naar opmerking Deel via andere websites More sharing options...
